Eigenvectors to XLS (API)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
PLease try:
Dim RNDD As RobotNodeDisplacementData
then in loop
Set RNDD = Robapp.Project.Structure.Results.Nodes.Buckling.EigenVector(....
Rafal Gaweda
marcinrakus
It seems that You do everything fine, and this may be a bug in RSA.
There is always a workaround - instead of EigenvectorServer You may use AnyResultServer:
    Dim NEWRES As RobotUniversalResultAccess
    Set NEWRES = Robapp.Project.Structure.Results.Any
    Dim ux As Double
    Dim uy As Double
    Dim uz As Double
    Dim ux2 As Double
    Dim uy2 As Double
    Dim uz2 As Double
    Set AllObjects = Robapp.Project.Structure.Nodes.GetAll
    Robapp.Project.Structure.ResultsFreeze = False
    Robapp.Project.CalcEngine.AutoFreezeResults = False
    For ii = 1 To AllObjects.Count
        Set Node = AllObjects.Get(ii)
        Cells(row, 2) = Node.Number
        Cells(row, 4) = Node.X
        Cells(row, 5) = Node.Y
        Cells(row, 6) = Node.Z
        NEWRES.Node = Node.Number
        NEWRES.LoadCase = 1
        NEWRES.Mode = mode1
        NEWRES.ResultId = 234
        ux = NEWRES.ResultValue
        NEWRES.ResultId = 235
        uy = NEWRES.ResultValue
        NEWRES.ResultId = 236
        uz = NEWRES.ResultValue
        Cells(row, 9) = ux
        Cells(row, 10) = uy
        Cells(row, 11) = uz
        NEWRES.Mode = mode2
        ux2 = NEWRES.ResultValue
        uy2 = NEWRES.ResultValue
        uz2 = NEWRES.ResultValue
        Cells(row, 13) = sf * ux2 + ux
        Cells(row, 14) = sf * uy2 + uy
        Cells(row, 15) = sf * uz2 + uz
        row = row + 1
    Next ii
You may find refactored code in attachment.
Tip - be language independent:
            RSelection.FromText ALL
            'instead of above this should also work
            Set RSelection = Robapp.Project.Structure.Selections.CreateFull(I_OT_NODE)
Ask if any questions.
Marcin
i tried that without any success, but Marcin solution works. Thank you both!
Euge_I
So sorry, but I have tried this solution, and the results read by VBA are different  from the ones in Robot
On the other hand, the solution done by @marcinrakus does work.
Thanks!
