Provided Reinforcement - Column - what are Advanced Options?
Hello.
Provided reinforcement (Column) > Calculation options > Advanced option
Here we have three options to select: shear considered, cracking considered and stresses considered. How does it influence the calculation? What's the meaning of each option?
Camila.
@Anonymous Artur Kosakowski edited the topic from 'Provided Reinforcement - Column' for better findability.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
By default the RC Column is designed against ULS axial force + bi-axial bending. By marking these check boxes you include shear forces and SLS conditions (crack limit and allowable stress value) as well.
Artur Kosakowski
Thanks for your answer. Just one more question. Is this allowable stress value referent the item 7.2 of eurocode 2?
Thanks again,
Camila.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Correct.
Artur Kosakowski
Your insight on this should be added to the RSA documentation -- which currently does not give this information:
http://help.autodesk.com/view/RSAPRO/2018/ENU/?guid=GUID-3602616A-6E0D-4E9B-BC36-D7241FA345CC
