I am looking for a simple way to model a heavy nonstructural wall in my structure. I read that curtain walls can be used in this case, so I modelled a curtain wall to represent my nonstructural wall. This seems to work very well to calculate the base reactions, but the load distribution to the intermediate beams is as shown in the figure below. In contrast, I need to distribute the load at the beams at the bottom level of each story (not at the top level as it is currently being distributed). For example, my roof beam would not take any load, and the beams below would take the full weight of the panel from ceiling to the floor. I guess I can just apply loads manually to simulate this wall, but I would like to hear your opinions. Thanks!
Solved by Romanich. Go to Solution.
Solved by Rafacascudo. Go to Solution.
I see 2 options. The simplest one is to use claddings that are 1cm shorter in a way that it doesn´t touch the upper beam. Making it one way vertical distribution ,all the load applied will go to the bottom beam.
The seconde option is to use a meshed shell orthotropic panel making it very weak in the horizontal direction.
See my answer on this thread to see how to do it
Additionally ,in your case you will have to assign a free edgel release to the top edge of all your walls in order to not having loads transfered to the upper beams.
Bellow the 2 options , meshed panel in the left. claddings to the right
Test model attached
Rafael Medeiros
Hi @brisid.isufi,
For the first method mentioned by @Rafacascudo the add-in is available:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-wallcutter/m-p/5588508
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
