Dynamo is now seamlessly integrated into Robot Structural Analysis Professional 2021 with the Dynamo Extension for Robot Structural Analysis. This extension is available through the Autodesk Feedback Community
This extension comes with the Structural Analysis Dynamo package containing nodes dedicated to Robot Structural Analysis program. The primary objective given the scope of capabilities is for Structural Engineers to use the new nodes to automate modeling tasks:
This new feature enhances the productivity of structural engineers and allows them to iterate through design options faster and more fluidly.
Once Dynamo Extension is installed you can run the Dynamo Extension from Add-ins > Dynamo command in Robot Structural Analysis 2021.
Hi @okapawal ,
I'm investigating the dynamo extension for Robot, and I got one question:
the "Case.Nature" that can be defined are only "dead", "live", "Snow" and "Wind"? It's not possible to manage in a "code dependent way" the Nature and sub nature? Reading in robot the current one, as it happen for cross section, or in a string text?
Thanks for support, have a nice day.
Hi
In the RSA exist 7 type of natures of loads: "dead", "live", "wind", "snow", "temperature", "accidental" and "seismic". This names are not a string only, it is a kind of nature type and cannot be set as the other one. In this moment only four of them are available in Dynamo extension "Case.Nature" node: "dead", "live", "wind", "snow". The rest of them can be set using Python node and native RSA API calls. In the current version of Dynamo extension is not possible to set sub-nature except native RSA API calls.
Regards Michal
Hi all,
I got a question about the extension.
Is it just the structural analyisis package which is now integrated or are there more features integrated?
Dynamo and RSA define load combinations
Gr Edward
The link opens Feedback forum.
You can find more information in the Documentation and install form Downloads
Where can we get Dynamo Extension for Robot Structural Analysis 2022?
I installed Robot Structural Analysis 2022, but it's not there.
Dynamo Extension for Robot Structural Analysis 2022 will be delivered as an add-in through Autdesk.Accounts.
It will be published soon in a couple days.
Dynamo Extension for Robot Structural Analysis 2022 is published. It is available as an add-on update to the program. You can find it in the Autodesk Desktop Application and on the Autodesk-Account portal.
I'm using the trial version of ARSA 2022. I'm not sure how I can download the dynamo plug in. Any suggestions?
Dynamo Extension for RSA 2022
http://up.autodesk.com/2022/RSAPRO/1AC1C282-A95C-387E-B735-3AD30749EADB//DynamoExtension_for_RobotSt...
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Hosam Elzohry , ACI , ACP, Autodesk Ambassador Gold
BIM Manager
https://www.youracclaim.com/users/hosam-elzohry/badges
Hello @elzohry2007 ! Where can I find the version for Robot 2021? I already had it, downloaded from the "Feedback community" site but now it is no longer possible to download. Thanks so much!
2021 Preview releases have expired as we released 2022 version of Robot Structural Analysis and the Dynamo Extension. I should have cleaned up the content on the Feedback portal.
You may still download Preview release of Dynamo Extension for Robot Structural Analysis 2021 from this link:
Hi Sir! I can't download with your link. Can you update your link, Please!
Do you mean Dynamo Extension for RSA 2022? The link to 2021 seems to work fine.
Copy the link from Hosan to separate tab, or try this one
