Divide large slab into small slabs that passes through beams
4 REPLIES 4
Djokaboris
216 Views, 4 Replies
Hi;
Please is there an tool in robot that helps to divide a large slabs  into small slabs that passes through beams. Will glad to know if there is. Here is the file attached
4 REPLIES 4
Hi @Djokaboris
you can cut your slabs with the "cut by plane" editing tool
there's no tool for cutting in broken lines. you'll have to cut and then edit, move, add, modify the points of the sub-parts.
Best Regards
your model is still unprocessed, have you noticed that the panels are superimposed?
I imported the panel from the revit structure model. Superimposed?? didn't noticed . But why are the loads from the slab not transfering to the beams Sir??
panels  748 751. you should also look at your geometry because bars and points are disjointed, which will cause problems in the model consolidation and calculation phases.
Technology Administrators
