Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Display Name of Releases / Select Bars based on attributes like releases
2 REPLIES 2
373 Views, 2 Replies
I was  working on a file and i had to use elastic releases on bars a lot. Its very very confusing to check the releases in the model graphically because there is no way to display the name of the release. Is there a way to display the name of the releases graphically.
Also, is there an option to select/display all the bars with same release. Similar to how we can select/display bars based on its attribute like section/group etc.
Vikas Venkatesha
AECOM (Benaim) Hong Kong
email: vikas.venkatesha@aecom.com
2 REPLIES 2
Refaat
Hi
“Is there a way to display the name of the releases graphically?”
Only in object inspector when you select the bar (see first capture).
“Is there an option to select/display all the bars with same release? Similar to how we can select/display bars based on its attribute like section/group etc.”
Yes, of course (as in the second capture).
  1. Press on bar selection button.
  2. From attribute select (release).
  3. RSA will select all the bars have the same release name.
I hope this will helps
Refaat - Libya
Rafal.Gaweda
Rafal Gaweda
