Display map for FE Envelope results
I want to take the envelope results for FE (slab) in different area for the design of the slab. However, on the Map view results, when we select all concerns load combination, only the Max values (positive moment in attachment) shown on the map seem correct. The Min values (negative moment in attachment) of envelope displayed on map are not the real Min values (but these seem to be Max of Negative moment).
This happens for both the kind of “value displays”: Finite Element Centers or Characteristic points
Can someone help me to display and take the Min values of Negative moment for the envelope of combinations?
mustafahesenow
Hi @Anonymous
Please be careful that when you view the result of bottom moment in certain direction under certain load combinations dont forget to choose the bottom envelope as show in the picture.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
It works well. Thank you very much.
