checking for gap between elements
Muhammed.OPERA
Advisor Advisor
Message 1 of 13
Muhammed.OPERA
Is there any command in RSA, which i can use to check wherever there's a gap between two panels or bars (beams, beam&panel) or not.
This gap happens some times but i know it from the meshing shape and of course it makes the program gives an instability warning.
@Muhammed.OPERA Artur Kosakowski marked @mustafahesenow post as the solution so that it is easier to find by others. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Replies (12)
Message 2 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Muhammed.OPERA
No, there is no such functionality Smiley Sad
Artur Kosakowski
Message 3 of 13
mustafahesenow
Hi @Muhammed.OPERA
I have some tricks to check this issues I will try to post a screencast for these issue within coming days.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 4 of 13
Muhammed.OPERA
@Artur.Kosakowski ok Smiley Sad thank you.
Facebook |LinkedIn
Message 5 of 13
Muhammed.OPERA
Yes please, Mr. @mustafahesenow
i think there's some use for the options ( Correct , Detailed Correct , Correct drawing model ) that can help me with my issue ?!
Facebook |LinkedIn
Message 6 of 13
mustafahesenow
Hi @Muhammed.OPERA  @Artur.Kosakowski
Here is the tricks How to Check the model continuity and how to fix the problem between the bars (columns, and beams)
Mustafa Hesenow
LinkedIn
Message 7 of 13
Muhammed.OPERA
That is really useful my friend, thank you @mustafahesenow
Facebook |LinkedIn
Message 8 of 13
Muhammed.OPERA
@mustafahesenow
I'll ask you a question that i'm sure you will laugh at Smiley Very Happy
What is the name of the program you used to record this video?
I like the way that shows the clicks on the mouse and buttons that you click on the keyboard.
Facebook |LinkedIn
Message 9 of 13
mustafahesenow
HI @Muhammed.OPERA
Its Autodesk screenxast
Mustafa Hesenow
LinkedIn
Message 10 of 13
Muhammed.OPERA
Thank you @mustafahesenow
I'm waiting for your next video eagerly.
Facebook |LinkedIn
Message 11 of 13
mustafahesenow
Hi @Muhammed.OPERA
Here it is .
Mustafa Hesenow
LinkedIn
Message 12 of 13
Muhammed.OPERA
Very very good my friend @mustafahesenow Smiley Happy
Thank you.
Facebook |LinkedIn
Message 13 of 13
mustafahesenow
Hi @Muhammed.OPERA
Mustafa Hesenow
LinkedIn
