Discrepancy in Self-Weight Calculation in RSA vs. Literature
15 REPLIES 15
Message 1 of 16
ugur_yavan_61
395 Views, 15 Replies
Hello everyone,
I am currently working on a project and encountered a discrepancy in the self-weight calculation of RSA . The self-weight computed by RSA is higher than what is reported in literature studies. I also manually calculated the weight using the length and unit density, and my results matched those in the literature, but not the RSA results.
Has anyone experienced similar issues or can explain why RSA's calculations might be higher than expected?
RSA calculation:
Python Calculation:
Literature:
15 REPLIES 15
Message 2 of 16
Hi @ugur_yavan_61
The best thing would be for you to share your project. Zip it first.
Best regards
Message 3 of 16
Here is the RSA project and one of many studies that find the results differently https://doi.org/10.1061/(ASCE)0733-9445(1992)118:5(1233)
Message 4 of 16
your link returns an "oops" message
Message 5 of 16
It works when you copy and paste it to the navigation bar. Interestingly directly clicking is not working. There must be something wrong with forum website I did not understand.
Message 6 of 16
Message 7 of 16
If you dont click the link and copy paste it to the navigation bar it works. And also it is not that important to reach the paper since I shared the results found in the paper.
If you multiply the areas with length and unit of density, you will find same result with paper however the RSA giving higher amount for same structure.
Message 8 of 16
Simau
in reply to: ugur_yavan_61
@ugur_yavan_61
There is no RSA model in your link.
As said by @Stephane.kapetanovic please zip and share your model
M. Agayr
Message 9 of 16
ugur_yavan_61
in reply to: Simau
I did as you said. Could you try running this file ?
Message 10 of 16
hi @ugur_yavan_61
the difference (5620/5734=0.980...) seems to correspond to gravity, are you sure of your comparison, of the densities and sections taken into account in your example, a mathematical simplification?
Best Regards
Message 11 of 16
I double checked everything. All the parameter are same except the calculated weight.
Message 12 of 16
Simau
@ugur_yavan_61
Maybe these kind of intersections are counted twice.
Try to remove them from the value displayed by Robot
M. Agayr
Message 13 of 16
HI @ugur_yavan_61
Could you comment on this table and tell us what evidence you have in relation to your verifications?
can you give us the value of the density you include in your calculations?
↑ the sections seem to be the same ↓
Without a comparative list, I can't check for myself.
Best Regards
Message 14 of 16
Here is the original structure and corresponding parameters from paper:
And here is my python results:
By the way, all of the  displacement and stress results matches for two model except the weight.
Message 15 of 16
hi @ugur_yavan_61
if all lengths and cross-sections are identical, do you agree that density
is not equals to
As Explain, the difference (5620/5734=0.980 ... 5734/5620=1.02) seems to correspond to gravity !
Best Regards
Message 16 of 16
it's a mathematical simplification in your example. the true value is the one calculated by Robot
Technology Administrators
