Disappearing model ??
jneves1990
jneves1990
Greetings everyone.
I have this peculiar problem. When a save is done in the model the "new" saved model loses properties.
Please find the two attachments.
In one picture it's shown the "old" model, and in another picture the "new" saved mode. (Bars and panels became invisible)
Does anyone knows why this happens?
Thanks in advance!!
João Neves
Rafacascudo
João,
I never use the building design template , but I guess it has relation with menu Geometry/stories/filter stories.
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to switch off the story filter.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
jneves1990
We tried that solution and it didn't work. Yet, by opening the new model with the repair mode the problem was fixed.
t.sautierr
I had once my model disappeared : when I set OpenGL acceleration to max in the preferences, when I put it back to medium then the model came back -> maybe a problem with the graphical chipset.
TuanNguyen2014
Have you set these members as inactive? if yes, activate it in Advanced Bar Properties. If no, you may have some errors in your current model. Close it and try to open in repair mode will solve this issue and all members will be active again.
