Different results between (Building Design) template and (Frame 3D) template
Message 1 of 13
Dear all,
I have a simple mezzanine to model. I used (Building Design) template then (frame 3D) template just to compare results. I assigned a live load equal to (4.79) KN/m^2 to both models, however, a huge difference in results ( reactions, deformation, combination, etc) appears, especially that one comes from the live load. I did many checks to ensure applying the same load value on the two models but everything is right. /see attachments/
Pls, could any explain what is going on and how to fix it?
Thank you in advance
Replies (12)
Message 2 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Screenshot does not give enough information to solve this issue.  Share both files for verification.
Krzysztof Wasik
Message 3 of 13
Okay .. pls download the files from the following link:
https://drive.google.com/drive/folders/1SAdvdLxN89H2JL4vHAwcKhu3Ll62Skgh?usp=sharing
Message 4 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
I cannot download file using attached link. Access is blocked
Krzysztof Wasik
Message 5 of 13
Dear @Krzysztof_Wasik,
Sorry for the delay. I have fixed the link problem and you can download the files now.
Pls click the following link to start downloading:
Message 6 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Models are different
In Building template model - slab is defined as meshed orthotropic plate which has non zero dead load and non zero stiffness.
In 3D slab template - slab is not defined - load is transferred to beams by weightless one -way cladding with no stiffness.
3D  frame template  does not support slabs. Slabs can be used in Shell model template or Building model template
Krzysztof Wasik
Message 7 of 13
I still don't understand why there is a big difference when showing reactions coming from Live load in both models. Although models are different, there is a slight difference when comparing reactions resulted from dead load, but a huge difference coming from the live load.
I mean the ratio of distributing loads to the supports in both templates is different, especially in the case of the Live load which is double approximately.
Message 8 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi I'n building model słab has non zero stiffness while in frame 3d three is no słab defined ,Cladding is geometrical object  Ii is used for load transfer to brama only  .Difference in fotce distribution is  caused  for live loads by different objects stiffness
Krzysztof Wasik
Message 9 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi  Try to define very small słab thickness in building model .Results for live load should be similar
Krzysztof Wasik
Message 10 of 13
So, in our case of a deck with one-way orientation, which model of both comes to the reality most ??
note:
In our case, there are no welded studs to fix the deck slab on the beams.
Message 11 of 13
Actually, I need to keep the deck slab in the current thickness and other predefined parameters which is exactly what i need to execute on-site. So, I can't suppose a zero thickness.
Message 12 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
If you need to take into account deck stiffness, building model is better
Krzysztof Wasik
Message 13 of 13
thank you. I just wanna transfer deck loads to the supporting beams. Then, I prefer to use the (3D frame )template.
I highly appreciate your response.
