Hi All,
I need help to figure out why my models are not working. Both of them have reported "no convergence of nonlinear problem". I did the second (UNDP Portal Frame Structure Rev 2) one as a control to the first and I got the same result. My manager also made an attempt but wasn't successful. Please find attached the link to the the models:
https://1drv.ms/u/s!AlmLGaDE55k7mSER6rSfxTs6-Ncx?e=6hazm7
The help would be surely appreciated.
Takunda.
Hi @takundat1
Check "Matrix update after each iteration" in Nonlinear Analysis Parameters for each non-convergent case.
You can do it quickly for all cases on selection.
To complete @okapawal 's comments:
- Add selfweigth sof the structure to the case #1
- Add some posts to the horizontal bracings
- Set simple cases 2 to 10 as "auxiliary
M. Agayr
model attached
M. Agayr
