How to create boundary condition for a grid like structure?
yiviw97057
yiviw97057
I have a grid structure made up only of beam elements for which I need to model supporting rectangular wall/column. This wall/column provides only restraint for vertical translation along its entire top line, while at the bottom line its fixed. Can I create this boundary condition using only beam elements?
Romanich
Hi @yiviw97057 ,
You can use linear releases along the top edge of the walls
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
yiviw97057
And is there a way to model the wall using beam elements? I can use 4 beam elements as seen below, but that wouldnt make it a wall, but 4 columns.
