Detailed structure correction not updating nodes
antonio.lafuente
antonio.lafuente
Hello
When trying to use the detailed structure correction I see the nodes Z coordinate is not being updated to that defined by the plane (z=3.434) . The program seems to be identifying the nodes that net be be corrected though. Am I missing something?
Rafacascudo
Your 1st line does not have the same Z coordinate as the 2nd and 3rd lines.
Another way to do it is ,
If you want all the selected nodes have the same Z coordinate ,select these nodes  ,open the nodes table only for these selected nodes and on the Z columm , right click on "Z(m)" and choose "fill special..."
set the correct value , hit OK and all node coordinates will change to the desired value.
Rafael Medeiros
