Hi everyone,
I have been trying design RC wall of manhole, but I can't. Because, when I was design RC wall and layout steel.
Structure show in picture bellow:
And modelling I was create:
I have some problem as:
1. I can't calculated design RC wall of manhole according to British standard.
2. I can't create circle on the RC wall when I was calculated and layout reinforcement.
I have seen video at link: https://www.youtube.com/watch?v=hNGov4oPYmk about created rectang but not apply for circle.
3. I can't layout reinforcement for wall of manhole as figure 1 (file .cad)
4. I don't know how to create earth pressure is true.
So, somebody can help me fix all this problem.
Thanks!
Solved by Artur.Kosakowski. Go to Solution.
Hi @Anonymous
As you have lateral load applied to the panels you should design them using the RC Slab module of Robot
I recommend watching the recording of the RC Design - workflows slabs, walls and wall foundations design webinar.
You can apply the soil pressure following the steps shown on this video.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Thank for your help!
I don't know how to create circle on the RC wall as modelling manhole I was show in figure 1. You can help me?
Thanks!
Hi @Anonymous
Just create a circular contour inside a panel. It will be automatically detected as an opening.
Thank you so much!
You can help me explain figure bellow:
And can I layout reinforcement on the RC Slab module ?
I'm sorry so much, I just study Robot for one day. So, I can't control everything of software for calculated.
Thanks!
Hi @Anonymous
Have you watched the webinar I indicated?
