Design colum Steel of Robot
athurD
Message 1 of 13
athurD
Hi. I want creative frame Zamil of robot same picture . I is attachments
Replies (12)
Message 2 of 13
Romanich
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 13
athurD
Thanks you Romanich.
You can help me next Picture???
Thanks you verry much.
Message 4 of 13
Romanich
Also, you can use shells for column:
Roman Zhelezniak
Message 5 of 13
athurD
Oh Good idie.
Thanks.
But do shell can connection same steel.???
Message 6 of 13
Romanich
Sorry, but I didn't understand your idea.
Also, if you want use tapered bar with one vertical flange, try to use Offset option. But note, as an Artur wrote - bar element is just the line that represents the center of the section with assigned attributes such as profile type.
Roman Zhelezniak
Message 7 of 13
athurD
Thanks You Romanich
Hi. You can toturial creative frame same picture???
Please tutorial video. Thanks you verry much
Message 8 of 13
athurD
Please !!
Message 9 of 13
athurD
Please help me !!
Message 10 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 11 of 13
can you write tutorial for example frame.zip in message 10 please???
thank you
Message 12 of 13
athurD
Hi.
please check message 4.
Message 13 of 13
HI thank you very much but i think steel in message 4 modeling as solid ??
i use method in message 10 in link below
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Column-with-section-change/td-p/3434495
please help me thank
modeling column steel in industrial building
