Additional Parameters (CAN/CSA S16-09 Code) - Selection for sway or (...)
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-5B1C7B9A-AD37-42F7-AF4A-A3BD4128FE1-972.htm
I cannot figure out what "Selection for sway or non-sway structure" is referring to.
I have received an email notification with Rafal's response in this thread, but it does not show up here.
Anyway, of course I know what a sway frame is. What I meant was that I do not see in this dialog the option listed in the description.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Patrick,
This definition is available in the buckling parameters part (the exact location depends on the selected design code). The line about sway / non sway definition is visible in Help for additional parameters by mistake. I have asked to have it removed from there.
Artur Kosakowski
That is what I thought, but wanted to make sure that I was not missing something. Thanks!
