Delete Cladding_ Calculating
luismrf
luismrf
i can´t  delete a cladding, i imported the model from revit, and the 1st floor is appears as cladding, so when i calculate i get warning that i have a separated structure, so i delete the cladding, but when i try to calculate the model again the cladding appears again.
how can i fiz this issue?
thaks.
okapawal
Hi @luismrf
Probably you used non-hosted area load in Revit, which is not placed in a level of an analytical panel.  Robot creates automatically claddings to distribute the planar load to members or panels.  But there is no object at this level and the model may be separated.
Redefine the area load as hosted in Revit, or remove and define it again in Robot to be applied to a slab.
Waldemar Okapa
Sr Product Owner
luismrf
Thank you,
@okapawal that was very helpfull, i solved the problem in the RSA, must be something i did worng in the revit but i don´t have that issue anymore.
