helli,
i want to calculate a ground slab supported in a lyme stone rock, but i don´t know what is the approprietad value of the Kz KN\m3, is it possible find this value in the RSA?
Thank you.
Luis
Solved by Romanich. Go to Solution.
Hi @luismrf ,
If you have a rock, you can input a very high Kz value, considering that the settlement will be close to zero.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Hi @luismrf ,
1,000,000 kN/m3 means that you will need 1000 kPa to get a 1 mm settlement, which seems reasonable. However, if you have a geotechnical report, you can check there.
Roman Zhelezniak
