Dealing with accidental eccentricities
Message 1 of 21
Hi friends,
I've read some posts about this topic but I'm not clear enough.
For example, in the code of my country (Venezuela) accidental eccentricity of 6% should be defined as follow:
Due to the code is not in RSA, I need to set a Modal analysis and then a Spectral analysis. Now I've read that the eccentricity should be introduce here:
I read that selecting Add nodal masses is more accurate.
But now, I need to define eccentricities in positive and negative directions. I usually do this defining a moment Tx = Vxi x 6%By (X dir) and Ty = Vyi x 6%Bx (Y dir) and then adding these moments in 2 load cases (Tx and Ty), then I combine these cases with the seismic ones in several combinations. For example:
See that when 100%Sx is acting also act Tx and when 100%Sy is acting also act Ty, and then changing signs and so on so on. Of course I want to know if its possible to do all this work with RSA. I think the answer is YES but how? I read something about define 4 modal cases and define something like:
So I want to know if it's correct and then how I combine these 4 modal cases with the seismic ones in a spectral analysis.
How do you deal with eccentricities?
Sorry if this post it too long but I think it will help several RSA users.
Best regards,
Cesar
Accepted solutions (3)
Replies (20)
Message 2 of 21
Simau
Hi cdmatheus,
assuming that the Z earthquake also acts you will get 96 combination
Modal 1 X- will give you
Sismic x,
simic y
simsic z
 and 12 newmark combination
same for modal 2 3 and 4, so you 48 combinations in total
when you add the 48 opposite combinations you get 96.
If your regulation is not in RSA, you must made them by hand.
M. Agayr
Message 3 of 21
mustafahesenow
Hi @Anonymous
Sorry to say that but this is wrong.Let me explain to you why.
In modal analysis there shouldn't have any eccentricities this very rare analysis and only used in some cases .
So you should have in your Model only one modal Case  without any eccentricity.
To create the seismic cases you have to fallow this steps :
1-After you create the modal analysis without eccentricity you create the typical seismic forces which doesnt include any eccentricity
So base on Above  you will have Sx , Sy , Sz
Sz could be Deleted its not affect the design for the typical building.
2-Create New seismic cases for each eccentricity
For example for ex=5% , ey = 0  See attach picture :
 As per the picture above New Sx , Sy , Sz will be created for the eccentricity assigned .
3-similar to above you will create new seismic cases for the other eccentricities
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 4 of 21
Hi @mustafahesenow
Many thanks for your help in this post and in the other one as well.
The problem here is that the dialog box that you display is for EC8, But due to the regulation of my county is not included in RSA I have to define a Spectral analysis rather than Seismic. When I define a Spectral analysis i dont see any place to introduce the eccentricities. So i am thinking that is not possible if the regulation is not in RSA. See picture below
Message 5 of 21
mustafahesenow
Hi @Anonymous
Cesar I think its very good point and this option need really to be implemented in the new version to allow the seismic eccentricity .
The problem that when you define the eccentricity from modal analysis this option will allow to change the mass location and the structure behavior will be totally different plus also the mass participation maybe less related to new Geometry . This is all will make the torsional moment much more than the value obtained by multiple the base shear by the given eccentricity .
Mustafa Hesenow
LinkedIn
Message 6 of 21
Simau
"The problem here is that the dialog box that you display is for EC8, But due to the regulation of my county is not included in RSA I have to define a Spectral analysis rather than Seismic. When I define a Spectral analysis i dont see any place to introduce the eccentricities. So i am thinking that is not possible if the regulation is not in RSA. See picture below"
No, it's possible
Excentricity definition  is not spectral module, but modal definition.
M. Agayr
Message 7 of 21
Simau
Sorry, again
No, it's possible
Excentricity definition  is not in spectral module, but in modal definition.
M. Agayr
Message 8 of 21
mustafahesenow
Hi @Anonymous
Please check this thread to have better understanding for this case.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/strange-stories-reduced-forces-result...
Mustafa Hesenow
LinkedIn
Message 9 of 21
Simau
So what is the point of having 2 possibilities in Robot?
via modal and via sismic,
Is one of them actually wrong?
M. Agayr
Message 10 of 21
Simau
To see what will happen to Mz, i made a simple modele with 4 configurations:
1_WO_torsion.rtd:             no excentricity
2_W_torsion_modal.rtd:   5m excenticity by modal widow
3_W_torsion_sismic.rtd:    5m excentricity by sismic window
4_W_torsion_load.rtd:       Offset load of 5m
Result
Fy is aproximatvly the same
Mz
No excent                   0 daNm  (logic)
Exc with modal           8304 daNm
Exc with sismic           35571 daNm  !!!
Exc with offset load    5503
So Exc with modal is the closest to reality
Any comment?
M. Agayr
Message 11 of 21
Hi @Simau
You got really useful results!
Also see the behavior of ex2 in model 2 and 3. I have no idea about it.
Message 12 of 21
mustafahesenow
Hi @Simau
They are different .
when you assign eccentricity on modal means that Geometrical eccentricity which is going to affect all the modal result and torsion of course will increase even the mass participation will be different  and mode shapes will be different at all. Anyway this case is very advanced and its not required by the code only in very special building . in addition to that this Technics is not exist only on RSA and we have to be proud of that . The other softwares Like Etabs , Midas etc the eccentricity only on seismic force doesn't exist in Modal analysis.
 Check this link for more information .
https://skghoshassociates.com/SKGAblog/viewpost.php?id=5
Mustafa Hesenow
LinkedIn
Message 13 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
In Robot there are two ways of defining eccentricities.
When you define it in the modal case you calculate it with the shift of masses so depending on the defined directions of eccentricities you will obtain different shape of vibrations. This approach requires definition of several modal cases one for each of the directions of eccentricities you want to include in the design.
When you define it in the seismic case (not available for a spectral analysis) you can have only modal case however as it is the 'simplified' approach the following points apply:
1. The modal analysis performed is not exact since it does not take into account the mass eccentricities. Therefore, the mode shapes are not the same as calculated with mass eccentricities defined for the modal analysis case.
2. The eccentricity of the mass is then considered "statically" in order to get the forces in the members. Therefore, the forces in the members are not exact.
3. This method provides the same base shear for all eccentricities. Only the values of reactions in specific supports are changed but the total base shears remain the same when changing eccentricities. So for instance for symmetrical building if the mass eccentricity is making it unsymmetrical the earthquake in X direction will still result in 0 base shear along Y and vice-versa.
I hope this helps.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 14 of 21
Hi @Artur.Kosakowski
Thanks for such a detailed answer. Any idea for define an accidental eccentricity in a spectral analysis besides in modal analysis tab?
Message 15 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
As it has already been mentioned for spectral analysis you can only define eccentricity in the modal analysis parameters Smiley Sad
Artur Kosakowski
Message 16 of 21
Thank you. I really appreciate your help.
Message 17 of 21
mustafahesenow
hi @Artur.Kosakowski
Could you please forward it to development team to be added . This is really important many thanks.
Mustafa Hesenow
LinkedIn
Message 18 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I have forwarded it.
Artur Kosakowski
Message 19 of 21
mustafahesenow
Many thanks for your Support.Its really appreciated .
Mustafa Hesenow
LinkedIn
Message 20 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I wish I could do more in return for your great help for this forum Smiley Sad
Artur Kosakowski
