Cross Sections Flat cross sections
I have modelled a solid rectangular section into 150x10mm flat plate as my cross bracing.
How do I ensure they carry tension only axial load in steel analysis and design?
Artur.Kosakowski
Autodesk Support
Autodesk Support
You need to declare it as tension only bar.
Artur Kosakowski
Hi Arthur,
I declared the flat plates tension only. I ran the calcs and the report is full of Type 1 instability in several nodes. why?
Note all the beams and bracings are modelled pinned-pinned and all the columns releases are left N/A(shell design)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Most likely there are too many releases defend. You may want to watch the recording of the 16th Robot webinar on this subject which is available from here.
Artur Kosakowski
