Critical load and critical coefficient calculation
What kind of steps should be done to get Critical load and coefficient for buckling. Is it possible calculate it with Robot for lattice construction?
Please refer to attachments.
Artur.Kosakowski
Autodesk Support
Autodesk Support
The buckling analysis in Robot is intended for global stability check rather than to determine the critical coefficients for each of elements of a model. For the tower as yours you may want to look at these values:
Artur Kosakowski
