Create panels in plane deformation structure type via API
mbrasiel
mbrasiel
I am working with the RSA API (RobotOM) using Python, and I would like to know whether it is possible to create Panels via the API in structures of the "Plane Deformation" type.
I can already create the contour geometry using CreateContour(). However, in a Plane Deformation structure, it seems that I cannot use I_LT_PANEL_THICKNESS, and I have not found a CreatePanel() or equivalent method in the RobotOM API that reproduces the operation available in the Robot interface.
Is it possible to create a Panel through the Robot API (RobotOM) in a Plane Deformation structure?
Thanks!
Stephane.kapetanovic
Hi @mbrasiel
The difference between a contour and a panel generally lies in the meshed attribute
Objects.Get(id).Main.Attribs.Meshed = 1
However, you should also check whether the panel, is compatible with your analysis method.
Could you share your code?
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
mbrasiel
The code below is working fine if I start a new project as Shell Design. But it doesnot work if I start a projetc as Plane Deformation structure type.
def create_single_panel(robot_app, structure, points_list, thickness_name):
    points = robot_app.CmpntFactory.Create(IRobotComponentType.I_CT_POINTS_ARRAY )
    points.SetSize(len(points_list))
    for i, (x, y, z) in enumerate(points_list, 1):
        points.Set(i, x, y, z)
    objNumber = structure.Objects.FreeNumber
    structure.Objects.CreateContour(objNumber, points)
    panel = structure.Objects.Get(objNumber)
    panel .Main.Attribs.Meshed = True
    panel .SetLabel(IRobotLabelType.I_LT_PANEL_THICKNESS, thickness_name)
    panel .Update()
    panel .Initialize()
    return objNumber, panel
By default, the panels do not appear to be filled, but calculations can be performed in "plane stress structure design" mode.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @mbrasiel
Objects (panels) defined as Plane deformation structure do not use thickness definition. In case of such panels only one parameter applied to panel is material. Plane deformation finite elements are simplified finite element type where deformation in direction perpendicular to panel plane is assumed to be zero. While model simulation,fFor such type of elements thickness attribute is not used calculations
Krzysztof Wasik
Objects.Get(id).SetLabel I_LT_SOLID_PROPERTIES, "CONCRETE"
bhavani_sankuratri
Hi @mbrasiel ,
Hope you are doing good! I wanted to follow up and see if you had a chance to look into the responses from Krzysztof_Wasik  and Stephane.kapetanovic . Please let us know if their explanations and suggestions helped answer your question or if you still need any assistance.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Bhavani Sankuratri
