CPython 3, Apply loads to Load cases
stefanyC6JZ7
Message 1 of 9
stefanyC6JZ7
Hi all,
We are trying to migrate our scripts from IronPython2 to CPython3.
I am trying to apply loads to the load case "GCW" as picture shows. The original script is attached, it was done with version IronPython2 and it works, however when turning to CPython 3, there are some errors.
Warning: AttributeError : '__ComObject' object has no attribute 'Records' [' File "<string>", line 32, in <module>\n']
and I got problems with IRobotLoadRecordMngr.Count. Could you help me checking what is wrong with the script?
Thank you in advance.
Files are attached.
Best regards,
Stefany
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
sys.path.append(user+r"\Dynamo\Dynamo Core\2.11\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
clr.AddReference('interop.RobotOM')
#clr.AddReference(user+r"\Dynamo\Dynamo Core\2.11\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
objects = IN[0]
LoadCaseID = IN[1]
ILRT = IN[2]
LoadPX = IN[3]
LoadPY = IN[4]
LoadPZ = IN[5]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
CreatedLoads = []
case = structure.Cases.Get(LoadCaseID)
simplecase = IRobotSimpleCase
simplecase = case
rec = IRobotLoadRecord
IRobotLoadRecordMngr = simplecase.Records
count = IRobotLoadRecordMngr.Count
for i in range(count+1)[::-1]:
	rec = simplecase.Records.Delete(i)
#for i in range(1,count+1,1):
#	rec = simplecase.Records.Delete(i)
for j in range(len(objects)):
	for k in range(len(objects[j])):
		Uniform = []
		Uniform.append(simplecase.Records.New(ILRT))
		LoadRecord = simplecase.Records.Get(Uniform[0])
		LoadRecord.SetValue(0,LoadPX)
		LoadRecord.SetValue(1,LoadPY)
		LoadRecord.SetValue(2,LoadPZ[j])
		LoadRecord.Objects.FromText(objects[j][k])
		CreatedLoads.append(LoadRecord.UniqueID)
application.Visible = True
application.Interactive = True
application.Project.ViewMngr.Refresh()
#Assign your output to the OUT variable.
OUT = CreatedLoads, count
Replies (8)
Message 2 of 9
1234eddie
Hi All,
Some of you may recognise these text from the script. @stefanyC6JZ7  is my colleague.
@JacquesGaudin @cool.stuff @chjpcoi
Hope someone of you explain to us what is nessesary to get our scripts to Cpython3.
Thanks in advance.
Gr Edward
Message 3 of 9
JacquesGaudin
Try this?
import clr
objects = IN[0]
LoadCaseID = IN[1]
ILRT = IN[2]
LoadPX = IN[3]
LoadPY = IN[4]
LoadPZ = IN[5]
CreatedLoads = []
simplecase = IRobotSimpleCase(case)
rec = IRobotLoadRecordMngr(simplecase.Records)
count = rec.Count
	rec.Delete(i)
		Uniform = []
		Uniform.append(rec.New(ILRT))
		LoadRecord = rec.Get(Uniform[0])
Message 4 of 9
stefanyC6JZ7
Hi @JacquesGaudin,
Thank you for your reply. I have tried the code you suggested, but it is not working completely. The first part of the script runs without a problem, at line 42 the set value does not correspond because of the com_object error, please see picture below.
what could be a solution for this one?
as a test i did turn line 42-46 off. the loop and everything then works.
Best regards,
Stefany
Message 5 of 9
1234eddie
@JacquesGaudin
we still having problems with this one. i did a little dig in the api.
i think i know why this happens, but don't know how to solve it.
Setvalue is part of Irobotloadrecord,
And our definition of loadrecord in the script is (if i'm right) part of IRobotLoadRecordMngr
could this be the problem.
Gr Edward
Message 6 of 9
JacquesGaudin
@1234eddie @stefanyC6JZ7
You are right, the `SetValue` method is not available because `LoadRecord` is not recognised as a IRobotLoadRecord object but rather a generic COM object.
In general, when this happens, the solution is to just cast the object to the expected type:
LoadRecord = IRobotLoadRecord(rec.Get(Uniform[0]))
# This forces the result of the `Get` method to be cast to IRobotLoadRecord
# In general:
# my_obj = ExpectedType(object_server.Get(i))
This is due to the way PythonNet works and to the fact that there is no such things as interfaces in Python.
IronPython was dealing with the interface types under the hood but PythonNet doesn't do that, leaving some objects with a generic COM object type. To gain access to the methods of the object, it is necessary to cast the object to the correct type.
import clr
objects = IN[0]
LoadCaseID = IN[1]
ILRT = IN[2]
LoadPX = IN[3]
LoadPY = IN[4]
LoadPZ = IN[5]
CreatedLoads = []
count = rec.Count
	rec.Delete(i)
		Uniform = []
Message 7 of 9
stefanyC6JZ7
Hi @JacquesGaudin
Thank you for your reply, and for your help. Now the code works better, loads are applied to the load case, see picture below. But, I got an error with lines 48 and 49.
Warning: TypeError : No method matches given arguments for FromText: (<class 'int'>) [' File "<string>", line 48, in <module>\n']
Warning: AttributeError : 'IRobotLoadRecord' object has no attribute 'UniqueId' [' File "<string>", line 49, in <module>\n']
Could you help me to solve it?
import clr
#sys.path.append(user+r"\Dynamo\Dynamo Core\2.11\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
#clr.AddReference('interop.RobotOM')
objects = IN[0]
LoadCaseID = IN[1]
ILRT = IN[2]
LoadPX = IN[3]
LoadPY = IN[4]
LoadPZ = IN[5]
CreatedLoads = []
#rec1 = IRobotLoadRecord(simplecase.Records)
count = rec.Count
	rec.Delete(i)
		Uniform = []
		#LoadRecord.SetValue(LoadPZ[j])
		CreatedLoads.append(LoadRecord.UniqueId)
		#selection_bars = structure.Bars.Get(objects[j][k])
		#LoadRecord.Objects.FromText(objects[j][k])
		#LoadRecord.Objects = '1'
OUT = objects, selection_bars
#OUT = CreatedLoads, count
Thank you in advance for you help.
Best regards,
Stefany
Message 8 of 9
JacquesGaudin
The first error is because the `FromText` method expects a string argument, not an integer. Just cast the integer to a string to fix it.
LoadRecord.Objects.FromText(str(objects[j][k]))
The second is because the IRobotLoadRecord interface doesn't provide `UniqueId` as an attribute. To access it you have to use an interface that derives from IRobotLoadRecord but is more specific. For a uniformly distributed load, it is IRobotLoadRecordLinear3D.
		Uniform = []
		LoadRecord = IRobotLoadRecordLinear3D(rec.Get(Uniform[0]))  # A more specific interface must be used
		LoadRecord.Objects.FromText(str(objects[j][k]))  # Converts integer to str
Note you could apply the same loads with this:
for obj_lst in objects:
	Uniform = []
	LoadRecord.Objects.FromText(' '.join(str(el) for el in obj_lst)
Message 9 of 9
stefanyC6JZ7
Hi @JacquesGaudin
Thank you very much for your help and patience with us while trying to fix the script. Now it is working, and I am happy to share the results below.
Have a nice day!
import clr
objects = IN[0]
LoadCaseID = IN[1]
ILRT = IN[2]
LoadPX = IN[3]
LoadPY = IN[4]
LoadPZ = IN[5]
count = rec.Count
	rec.Delete(i)
		Uniform = []
OUT = objects
Best regards,
Stefany
