cover does not satisfy environment requirement /problem help
The thing is that cover that you choose is too small than code regulations needs - for enviroment class that you provided (analisys --> story parameters: for example XC, XD, ... XA)
You can modify cover and deviations in Analysis > Calculation Options (as in the windows information says) or change the enviroment class - if it's possible in your case.
More info about enviroment class definition and required covers you can find in Eurocode 2.
try to increase your concrete cover for your beams as is suggested;cover.png
