Code combination Regulation question
mustafahesenow
Advisor Advisor
mustafahesenow
Hi All,
What mean W and T in the code regulation formula ? see attached picture
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
According to my knowledge Temperature and Wind respectively.
Artur Kosakowski
mustafahesenow
Hi @Artur.Kosakowski
The problem there is no columns for wind and temperature all are under Live load
The way have this regulation is really mess its cant controlled 100%  when we generate the load combinations alot of nested combinations appear which are really affect the design So automatic combinations is not accurate .
Mustafa Hesenow
LinkedIn
mustafahesenow
I think it could be much more organised  by having columns to each case Dead load , live load , Snow , Wind, Temperature , and Seismic
Or at least to activate this option that W for wind and T for temperature and possibility to add  user formula
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I agree that having e.g. a table where you could mark which load act together with others would be nice and this is one of the proposal for the code combination generator improvements.
Perhaps you could consider automatic generation of manual combinations in some sequences instead?
Artur Kosakowski
