- Mute
- Permalink
- Report
I am having trouble with core results in Robot: it gives me diverging results when there is a significant change in the lateral stiffness (change in width of the building, base of the core, etc...).
To check the core results, I made a very simple model: a rectangular core, with a flawless meshing, simple levels, and I applied only lateral loads (2 cases: point load on the center of the slabs, or surface load on the walls; each case is equivalent to a 100kN-lateral loading per level, except on the top level).
In both loading, the core results are not consistent, espescially at base level:
Where does this come from? Is there something wrong in my model?
Thank you for your help,
Benjamin
