Core non consistent results
I am having trouble with core results in Robot: it gives me diverging results when there is a significant change in the lateral stiffness (change in width of the building, base of the core, etc...).
To check the core results, I made a very simple model: a rectangular core, with a flawless meshing, simple levels, and I applied only lateral loads (2 cases: point load on the center of the slabs, or surface load on the walls; each case is equivalent to a 100kN-lateral loading per level, except on the top level).
In both loading, the core results are not consistent, espescially at base level:
Where does this come from? Is there something wrong in my model?
Thank you for your help,
Benjamin
Artur.Kosakowski
Autodesk Support
Autodesk Support
This is caused by the precision of panel cuts through the panels (precision of distribution of forces 'across' surface elements governed by their shape function).
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The diagram with the values taken from the centers of the elements as it is displayed in RSA 2018.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
The change of the display of the core walls diagrams as discussed in the topic indicated in the above post has been introduced in HF1 for RSA 2019.
Artur Kosakowski
