Connexion beam-beam
Connexion beam-beam
Connexion beam-beam
I would like know if its possible to make an assembly in robot between the two beams (IPE 100) because Robot doesn't want to do it.
The capture of the connexion is attached.
Thank you for the answer.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Te beams have to be perpendicular. Try the following:
1. Divide the skewed beam into two parts with the one closer to the 'main' beam being very short
2. Make this short part perpendicular to the 'main' beam
3. Create a connection between the 'main' beam and the 'short' one.
As it is only shear force capacity check this should not significantly influence its value.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
