Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Connection Report input/output
4 REPLIES 4
rbaraldi
266 Views, 4 Replies
I am checking some connenctions in ROBOT and there is one check for Bending on the contact surface with plate or connected element where I can not find how the Plastic section modulus is calculate for this check (what the program is considerng).
Also,
Is it possible print the inputs and outputs like formulas and calculation sequence ?
attached the image and the model.
Kind regards,
Rafael Baraldi
4 REPLIES 4
Simau
in reply to: rbaraldi
@rbaraldi
No files attached.
Model must be zipped before attaching
M. Agayr
rbaraldi
in reply to: Simau
Hi Simau,
Sorry about that.
Please find attached the file.
Thanks.
hi @rbaraldi
it looks more like the plastic section of the plate to the right of the welds (8mm), which is why you have a reduction in the modulus
4139 seems good for UB 610 x 229 x 140
Best regards
It is make more sense now.
Thanks !
