I am checking some connenctions in ROBOT and there is one check for Bending on the contact surface with plate or connected element where I can not find how the Plastic section modulus is calculate for this check (what the program is considerng).
Also,
Is it possible print the inputs and outputs like formulas and calculation sequence ?
attached the image and the model.
Kind regards,
Rafael Baraldi
Solved by rbaraldi. Go to Solution.
Solved by Stephane.kapetanovic. Go to Solution.
