CONFIGURE TEMPLATE ON ROBOT
Message 1 of 8
I have a problem. I want the name that i choose to my bars show in the plot.
In place of the number "1" i want that show "p41" - The text "P41" i insert in revit, before send the model to RSA
Could you help me?, i need the correct name of the variable to choose this template.
This is the only way that the ROBOT and Revit will have the same number to the elements
Sorry, i don´t speak english, only portuguese.
Replies (7)
Message 2 of 8
Muhammed.OPERA
Hi @Anonymous
you can change the element name from the : RC component inspector right click on the element and choose edit > Rename or just press "F2" after choosing.
The name you write is the exact name to be shown in the Plot.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 3 of 8
It's an option, but i a have a hard work in revit to named the elements. I don't want to do this again in robot. It's not smart and i can make a mistake doing it manually.
Is it possible export this name back to revit? To use a tag
Thanks!
Message 4 of 8
Muhammed.OPERA
@Anonymous
I'm sorry i don't know.
I hope someone will help with another solution if there's.
Facebook |LinkedIn
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The tags assigned in Revit are not recognized in Robot. The only way to have the same element numbers is to edit them in Robot manually or with the numbering options.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 6 of 8
Is there a way to see the number id of robot elements after i send the model to Revit?
It is a simple error, but cause great troubles.
I Think Autodesk nerd to correct this.
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
According to my knowledge there is no such possibility.
Artur Kosakowski
Message 8 of 8
Muhammed.OPERA
I recommend you to sign that petition asking AUTODESK to do serious development on Robot and to save it.
https://www.change.org/p/autodesk-save-our-rsa-structural-engineering-is-not-a-game?recruiter=853913...
Thanks.
Facebook |LinkedIn
