Announcements
Concrete slab reinforcemnt. The concrete cover issue.
Jummybear
Jummybear
I cant understand the calculation error message: The cover does not meet the code requirements: 2.5cm<2.6cm. The cover does not meet the code requirements: 2.5cm<3.0cm
Slab of concrete C30/37. Structure class S4, Environmental class XC1. I set the cover c1 and c2 as 1.5cm which should meet the code req as minimum allowable cover + 1cm is standart deviation.
Have I missed something?
Thanks for help.
Replies (8)
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please
Rafal Gaweda
h_s_walker
Working in the construction industry (sort of) as I do. That 15mm cover sounds very bad. You should set your minimum cover to at least 2.5cm (25mm)
Howard Walker
Left Handed and Proud
Jummybear
File attached.
Jummybear
Any suggestions?
PS We are using ARSA 2015 atm
Rafal.Gaweda
Autodesk Support
Autodesk Support
Basing on 4.4.1 EN 1992-1-1 and 4.4.1.2(3) Cmin,b code tables \ paragraphs
it can be found that
for fi 12 - min cover is 25mm
for fi 16 - min cover is 26mm
for fi 30 - min cover is 30mm
Rafal Gaweda
Jummybear
Can you paste an exact table with the values from the code? I cant find any concrete cover values which are depending on reinforment diameter. Attaching the pdf from the 1992-1-1 code with chapter 4.4.1. Untill now, we pick the exposure (environmental) class and Structure class and proceeding to table 4,4N where you pick the cmin,dur. In my case its 15mm (XC1, S4).
Rafal.Gaweda
Autodesk Support
Autodesk Support
undefined
Rafal Gaweda
Jummybear
Thanks. I forgot that fact that Robot uses all possible reinforcment diameters for auto reinforcement if I do not pick necessary diameters. Tried with only 10 and 12mm bars - everything ok wothout any warnings. Topic solved 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
