How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I cant understand the calculation error message: The cover does not meet the code requirements: 2.5cm<2.6cm. The cover does not meet the code requirements: 2.5cm<3.0cm
Slab of concrete C30/37. Structure class S4, Environmental class XC1. I set the cover c1 and c2 as 1.5cm which should meet the code req as minimum allowable cover + 1cm is standart deviation.
Have I missed something?
Thanks for help.
Working in the construction industry (sort of) as I do. That 15mm cover sounds very bad. You should set your minimum cover to at least 2.5cm (25mm)
Howard Walker
File attached.
Can you paste an exact table with the values from the code? I cant find any concrete cover values which are depending on reinforment diameter. Attaching the pdf from the 1992-1-1 code with chapter 4.4.1. Untill now, we pick the exposure (environmental) class and Structure class and proceeding to table 4,4N where you pick the cmin,dur. In my case its 15mm (XC1, S4).
How to buy
