i was wondering, when you define a new concrete section using the section definition module in robot, and give it a concrete material property rather than steel, then save it to database. When you then define say a beam within a model and call up the section, you have yo go into steel to get the concrete section you defined under user? Why is it shown under steel and not concrete? Or is there something i am doing wrong? I know you can just draw the section as a bar in the model and then change its properties in the properties when you click on the bar/beam however it would be nice if i didn’t have to do this? Any help or comments would be appreciated.
Simon.
