- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys,
I am trying to check properties relating to the coefficient of thermal expansion of concrete sections. If I select a panel I can see from the panel inspector that the value of LX (which I assume is coefficient of thermal expansion) = 0.00 (1/oC). I know that the value for coefficient of thermal expansion is a low number, typically 10X10-6 (10 microstrain.) so is this a display issue? When the slab has temperature loads applied it does undergo elongation / shortening as expected so there must be some value here and not simply 0. Also how do you override the material properties in Robot?
Thanks for the help,
JL
