Complex shape modeling
Message 1 of 14
Hi guys,
So I'm trying to model a complex shape as in the picture below, I've tried different ways to create this shape but I alawys fail.
So I'm asking if there is anyway that I can remove the intersections of the panels shown in the picture to get the reqired shape?
and if there are any other ideas to create this model, please suggest it 🙂
models are attached,
thanks 😄
@Anonymous Artur Kosakowski marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (13)
Message 2 of 14
Rafacascudo
Do you want a spheric dome or the curve d panel strips are to be cylindrical?
Rafael Medeiros
Message 3 of 14
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 4 of 14
Hi @mustafahesenow,
First of all, thanks for the new method that I've learned from you,
but when I did it to the whole shape, the meshing got really bad and not defined on the element correctly!
So what am I doing wrong, in order to avoid these problems? thanks.
Here is an example of what I got some areas without mesh, model is attached.
Message 5 of 14
Hi @Rafacascudo,
what I want is similar to a dome but with some cuttings (I don't have a word for this shape Smiley Frustrated ) , but the picture below shows the shape I want.
Message 6 of 14
Any ideas? I'm still facing errors when I do this model.
Thanks. Smiley Happy
Message 7 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm attaching the meshed model however you need to have RSA 2019 to open it.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 8 of 14
Hi @Artur.Kosakowski
Thanks for helping Smiley Very Happy, but can you tell me the method used to do the model , or the meshing?
btw the attachement is an image.
Thanks Smiley Very Happy
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Conversion to ACIS and Union of all panels however with some additional action that you will not be able to do in the current commercial version of RSA. Smiley Sad
I'm attaching the rtd file I missed. I hope it will help. Smiley Happy
Artur Kosakowski
Message 10 of 14
Hi @Artur.Kosakowski,
I mannaged to do my model, however compared to your results, I've found a difference!
So by any chance if you can check my model and see what I've done wrong ? Smiley Sad
The first picture is your model displacement after changing the supports to fixed, the below it is my model!
and thanks alot @Artur.Kosakowski Smiley Very Happy
Message 11 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Check the materials (thickness in both models).
Artur Kosakowski
Message 12 of 14
In my model when I try to change the thickness it doesn't change Smiley Sad , every thing in the properties tab doesn't change! what is the reason?
Thanks.
Message 13 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
For extruded / revolved / ACIS panels the thickness label is not displayed in the Inspector as it is assigned to its sides.
Artur Kosakowski
Message 14 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Do you still need any additional help for your model? If we managed to provide you with the solution would you mind marking the corresponding post as such? Thank you.
Artur Kosakowski
