I trying to place cladding on a very irregular 18 storey building. what will be the best way to carry out this procedure to get the best load distribution from the wind load simulation. Any help will be deeply appreciated.
Solved by Rafacascudo. Go to Solution.
Can you show us the building? I would suggest you to use contour cladding if it is as irregular as you say...
Rafael Medeiros
