Check total stability of structural
Nissar19
Nissar19
Hey!
I wonder at which SLS combination, we can use to check total stability of structural?Capture.PNG
Accepted solutions (4)
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Nissar19
Shouldn't it be each of the defined ULS combinations instead?
Artur Kosakowski
Nissar19
I'm not really sure That is the reason why i m asking. I thought to control total stability we use SlS characteristic
Nissar19
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Nissar19
IMHO SLS combinations are for deflection/displacement check rather than the overall stability one.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Nissar19
Thanks very  much
