Reduced results for wall panel with openings supported on a steel beam
hi,
I was wondering could somebody give me a an explanation for a result which I have from a wall panel. The wall panel has 3 openings as per the attached pdf. It is supported on a steel beam continuously under the wall panel at its base, the steel beam is then further supported on primary beams either side. I have taken 4 panel cuts along the bottom of the panel for a specific load combination (which is permanent dead load i.e. all vertical dead load acting downwards). the end panel cuts to the piers at each end of the wall (A1 and A4) have given me a downward force (-) and the panel cuts for the two central piers (A2 and A3) have given me an upward force? is this correct and is it to do with the stiffness of the beam compared to the stiffness of the wall i.e. the wall is a lot stiffer/rigid?
As I was trying to take the panel cuts so as to design the beam separately outside RSA so as to get bending moment diagram with loads directly acting down on beam.
Simon.
