Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
characteristic strength of concrete
5 REPLIES 5
595 Views, 5 Replies
hello,everyone,
Why when i am change the (characteristic strength of concrete) from grade to another the quantity of steel remain the same , especially in foundation ???thanks....
5 REPLIES 5
Refaat
Hi @hazim.slevane
Could you attach specific  example to clarify your inquiry ?
Refaat
Romanich
It might happen in the case when you have only minimum reinforcement according to a design code.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
in reply to: Romanich
It is normal. It is not by increasing the strength og the concrete that you'll change a lot the reinforcement ratio (with the same effort).
Try with an excel sheet to see..
Do you mean there isn't relationship between concrete strength and steel ratio????
No but the tensile strength of concrete is less or neglected in the fiber subjected to tension. So that it does not impact really your sizing.
Look to the formulae calculating the As...
