Mesh Optimization
Mesh Optimization
Mesh Optimization
Estimados,
No logro generar la malla de este silo (les comparto solo una parte) en tiempos razonables. En otras palabras, no he podido obtener la malla debido a que Robot se demora mucho. ¿Cómo puedo generar la malla de este modelo?
https://www.dropbox.com/s/b2yonnign8pnimt/Mesh_optimization.rtd?dl=0
Muchas gracias,
Daniel
Rafacascudo
The big problem I see is that your 200mm side arc discretization for a 10.5m diameter is too small . In a way that you have a series of individual vertical panels of 200mmx1800mm . With a mesh size of 250mm for all panels ,it surely will take quite a long time to mesh it all.
Probably a side for the circle around 600mm to 1000mm would be enough to get good results.
Also , for so many panels , never mesh it in just one go. I just meshed 3 levels one at a time in your original model with no modifications and it meshed fastly ,although the mesh is very far from beaing considered good.
Rafael Medeiros
