Change of local Z axis sense with Robot API
LuisCRodrigues
Message 1 of 9
LuisCRodrigues
I want to change the sense of local Z axis of a panel using Robot API.
I've searched the API help and I didn't found any method to do so.
It has a method to define the local X axis but not the Z axis.
Does anyone knows a way to do this?
Thanks in advance.
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to use the following code which changes the orientation of the Z axis for the panel number 1:
Dim r As New RobotOM.RobotApplication
Dim o As RobotOM.RobotObjObject
o = r.Project.Structure.Objects.Get(1)
o.Main.Attribs.DirZ = 1
o.Update()
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 9
LuisCRodrigues
Problem solved!
Thanks for your help.
Message 4 of 9
Hi Artur,
Could you tell me how the z-axis and other  axes (x and y)will be oriented if I use the snippet of code provided by you? I am unable to figure it out?
Thanks in advance!
Message 5 of 9
Actually, I want my local coordinate axes for each panel to be such that the z-axis is always pointing outward.
Message 6 of 9
also, there is a syntax error with the following line:
o.Update()
Message 7 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
You have to check local Z vector and change it according to your needs
Dim RSel As RobotSelection
    Set RSel = RobApp.Project.Structure.Selections.CreateFull(I_OT_PANEL)
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSel)
Dim X As RobotGeoPoint3D, Y As RobotGeoPoint3D, Z As RobotGeoPoint3D
    Dim Obj As RobotObjObject
    Set X = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Y = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Z = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
        Set Obj = PanelCol.Get(1)
        Obj.Main.Attribs.GetLCS X, Y, Z
Rafal Gaweda
Message 8 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
o.Update()
This is C# code
In case of VBA : o.Update
Rafal Gaweda
Message 9 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Hint:
o.Main.Attribs.DirZ = 0  'default (assigned by program) local Z direction
o.Main.Attribs.DirZ = 1 ' opposite to default direction
Rafal Gaweda
