CANT SEE RESULTS CONNECT IN MS EXCEL
Message 1 of 9
Morning,
I've got Autodesk Robot 2018 and MS Excel 2016 installed in my computer.
I cannot see the Results Connect addin in Excel. Can you please give me a hand to activate it?
I have already confirmed/checked:
- Results Connect is installed.
- Have tried to activate it in Excel (Options/Addins/COM Addings) but does not appear. Perhaps I need a path to file? but does not know which file and where?
Thanks in advance,
sanjuan100
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
 Please follow the steps described in the attached document and confirm each of them.
Artur Kosakowski
Message 3 of 9
Dear Artur,
Can confirm that results connect is installed in my computer (step 1).
But I cannot see it (step 2) or mark/activate (step 3) in the Add-ins menu in Excel/options.
sanjuan100
ps I do not see "Autodesk Vault Addin for Office 2016" either if that has anything to be with this issue?
Message 4 of 9
Artur,
In the step 3, within File/Options/Add-ins -> COM Addins, there is the option to add a new one. If you let me know which file or the address where the file is stored, perhaps that's a way to make it work?
Message 5 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
What is exactly your Excel version? Have you tried to uninstall and install Results Connect again?
Artur Kosakowski
Message 6 of 9
Thanks Artur.
It's solved, it was an internal issue of permissions for writing/changing registry files.
Message 7 of 9
andgalb
Hi Artur
I am having issues with finding the Results Connect Addin which does not appear. My colleague has the add-in but when I search I can not find ASC.vtso|vstolocal which my colleague is using. Can you advise as I have had our IT investigate and  I have also uninstalled and reinstalled Robot and Results Connect.
Thanks Andrew
Message 8 of 9
hello...
I checked all of steps in document
I still can not find it from add-ins on Exel
Message 9 of 9
bartycorrea
did you find it? Could you add Resultsconnect to excel?
