Collinear cable example with intermediate support
To whom it may concern,
I am currently trying to use cable elements in a simple robot model however I am battling to obtain solution convergence of the assembly.
Essentially I want to model a cable which has a pretension of 1000 kN in it. The cable is has an intermediate elastic support in the vertical direction and is pinned at either end. The cable has been divided into to such that the intermediate support may be modeled making the cables collinear. Additionally, uniform loads are applied to the cables.
Please be so kind as to offer advise, urgently.
I have attached the example for reference.
Dane
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Here you are:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi @Artur.Kosakowski,
I did as indicated however, there is a strange displacement occurring on the right hand side. Note that our max displacements are the same.
Regards
Dane
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You display the shape with large scale therefore its shape due to the horizontal displacement of the support gets strange shape. You may want to display it in the structure scale instead:
Artur Kosakowski
Thank you for the assistance.
Please could you explain to me why there would be such a large displacement in the UX direction?
If this were a uniform cable resting on an elastic support I typically wouldn't expect this. Could this be as a result of the cable definition and how I have applied the initial prestress of 1000 kN?
Regards
Dane
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I think so. To keep exactly 1000 kN in both cables is difficult. As we always recommend I'd rather use elongation instead.
Artur Kosakowski
Thank you for the quick response and answering my question.
The quick response is much appreciated.
Regards
Dane
