When restarting calculations for non converged cases, am I anyway able to define parameters for several cases at once? Now it seems I have to change those non linear parameters for each case one by one. If I select many cases with cntrl on it still changes the parameters only for one case. Also in "define parameters" dialog there's a box which shows a selected case, but it gives a case name instead of a case number and it is not possible to list those non converged cases here to change calculation parameters for all of them. Ofc the best would be to have an option to select and edit calculation parameters for all of those non converged cases showed in calculation messages.
I'm just trying to reduce some calculation time...is my approach right? is this method helpful at all? : )
To change parameters at once, did you use this ?
M. Agayr
Modification of parameters in that dialog makes calculation restart option unavailable.
Anyone? I think theres no solution for this so it would be nice to have in a next updated Robot version..
