@biuro.xplan
RC calculation notes are generated out of templates in rtf format.  Each design code has separate templates.  You can edit them (but you really don't want to when you see the content).
Find attached templates for foundation EC design, without numbering.  Three files *.rtf.
Copy original files from "c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2022\Template\"  to a safe location for reference, if I made a mistake in my edits.
Replace with the attached edited files.  You will need admin right to overwrite files in this folder.
In order to see updated notes, you can rerun calculations.  Or just generate new note with Results > Calculation Note command.
	 Waldemar Okapa
Waldemar Okapa
Sr Product Owner
