calculation errors (Insufficient wall sec
Hello all engineers,
I analysied under ground tank  ,but when I designed wall of tank there is calculation errors
                                      (Insufficient wall section (11.10.9) )
How can I fix this errors ???
thank you ,
Artur.Kosakowski
Autodesk Support
Autodesk Support
IMHO you shouldn't design a tank wall as a shear wall (I assume you have out of the wall plane bending).
You may find slides 37 and 38 from the 5th Robot webinar helpful. The recording of the webinar is available from:
http://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td-...
Artur Kosakowski
