Calculating truss connection,what does adnotation mean?
FILIP.PAWLICKI00
FILIP.PAWLICKI00
So im calculating truss connection for my masters thesis.When i wanted to check results i obtained note that shear forces wasn't used,and the connection was treated like truss node connection.What does it mean. I see other softare takes shear forces into consideration.
Simau
Hi @FILIP.PAWLICKI00
Can you translate the annotation into English.
Otherwise in truss type there is only tension or compression
M. Agayr
