Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
calculate truss lower chord zero value
3 REPLIES 3
m_nikazis
268 Views, 3 Replies
When  I calculate steel truss, lower chord Moment and other forces is zero! in Full force table is normal value, but lower chord zero! RSA2020 and 2021
https://prnt.sc/12mrnt3
3 REPLIES 3
m_nikazis
in reply to: m_nikazis
Rafacascudo
hard to tell without the model ,as we don´t where are bar 65, supports ,loads.
Zip it before attaching ,if possible.
ps:pictures can be attached to message body. no need of an external link
Rafael Medeiros
Krzysztof_Wasik
Hi @m_nikazis
Forces table shows (by default) force values in bar end-nodes only. Since lower chord is defined as one continuous beam which goes beyond diagonals and probably is not supported at the end, axial force in lower chord end-nodes is zero.
To see forces in lower chord intermediate points, you have to present more points along chord length. Click right mouse button on active table > then Table columns from context menu > go to Division points tab. Select as many points as you need for presentation.
Krzysztof Wasik
Technology Administrators
